Thread: Help! Left on vacation and once back pump won't prime and Guests coming over
    MikeInMo is offline ** No working email address ** MikeInMo 0
    Oct 2004
    Default Re: Help! Left on vacation and once back pump won't prime and Guests coming over
    When you fill the pump basket and fire the pump does it drain the basket quickly as it normally would do?
    Yes, it seems pretty much the same in that regard.
    Any sign of overheating on the basket lid or pipe fittings at the pump?
    Don't think so but I really don't know what this would look like.
    Normally overheating of the basket area would occur when the output is blocked and you're just churning water in the basket and getting the water hot.
    This could well have happened not because of blockage necessarily but because of starved for water.
    Did your sister have to open the basket lid for any reason while you were gone? Look at the basket lid first then valves and finally the piping and bonded joints.
    Really doubt it but I'll check that seal again.
    Thanks for the help and followup response to my responses are Always appreciated.
    Mike
    Honesdale PA
    Hi Mike,
    the heating of the basket would occur when water is in it and not moving, not when dry. What happens is when the output is blocked and water isn't moving, a lot of the energy the motor puts out is transferred to the water by the impeller. Basically the old lab experiment where you stir a container of water vigorously and measure the temperature rise to determine how much energy you put into the water. With the power a pump motor can put out you can actually boil the water and regular PVC starts softening a little before boiling temps. Thus the integrity of any threaded PVC joints into the pump housing can be compromised. You can use vaseline to check for leaks at the joints. A lot cheaper than silicone grease and as long as you wipe it off and remove the last traces with an alcohol soaked paper towel you'll be ok. I don't think vaseline should bother the materials anyhow but leaving a residue will collect dirt. Don't use it on O-rings and seals though, like the basket lid seal. Use silicone grease.
    Since you have ruled out blockages I believe, the way it happened it sure sounds like an air leak. Just a matter of finding it. One more thing to try to get some idea if the pump seal is OK is to take off the basket lid and using a 5 gallon bucket pour water into the basket and let the pump circulate it. Maybe a couple garden hoses instead to provide enough water to build up some pressure. If you see any dribbles coming from areas that are normally dry then that could give a clue.
    St. Joe, MO
    How do you use Vaseline to check for leaks? I'm sure the answer will be obvious and I will look dumb, but I've just never heard anything about this...
    Merci beaucoup!
    Honesdale PA
    Vaseline is thick and forms a pretty good seal for checking suction leaks. Unless the leak is large the vaseline won't get sucked in as would water or something thinner.
