Results 1 to 8 of 8
Thread: Suggestion on Closing Above Ground Pool
    Tinley Park, Illinois, USA.
    Default Re: Suggestion on Closing Above Ground Pool
    Thanks Al.
    I am leaning towards closing my pool without any cover. I really don't get a lot of leaves although I do get some stuff that gets blown into the pool with all the wind and stuff. But, I can scoop that out with the leaf net before the water freezes.
    We're going to use the Aquador skimmer cover and the return plug. Do you suggest that we still drain the pool below the skimmer?
    24' Above Ground Pool x 54" depth -- 14,000 Gallons (approximately) -- 1 1/2 HP Hayward DE Filter (model EC 45) -- Hayward H150 Gas Heater
    I am in NY state, and I've used a mesh cover for the last 2 years. I've also left the pool uncovered over the winter. I believe you would have the same issue with the mesh cover as you do with the solid cover.
    Leaving it uncovered is fine, however you could also cover the pool until the leaves fall, then uncover it before it freezes to avoid having to scoop out the leaves. It may not be necessary in your situation, but it is an option that I've seen others suggest.
    I would still lower the water level below the skimmer. If you close the skimmer and plug the return, the precipitation accumulates in the pool all winter. That will cause the water (and ice) level to rise, and if it gets high enough, it will damage your rails. I actually leave my return unplugged until spring thaw, allowing the excess water to run out the return so the pool won't overfill. If you do that, put a board under the return on a slant to direct the water away from the base of the pool.
    Daisy11,
    Thanks for your reply. I'm so glad you told me that the mesh cover will do the same as the solid winter cover -- that's what we suspected too. I really don't get a lot of leaves, so we'll just leave it uncovered all winter.
    We will also take your suggestion and drain it below the skimmer. Over the weekend, we had so much rain that it is sitting very close to the rails. My husband is draining most of that rain water today. We had an algae bloom too unfortunately, so we're doing the shock, brush, shock treatment now before we close the pool. Hopefully, we'll get it back to stable by this weekend. I'd like to close the pool this weekend. The kids haven't been in the pool since they started school 3 weeks ago.
    Hmmmm.
    Put a horse in the pool.
    Then, when you want to close, just pull the plug!
    (Sorry--national silly season is upon us. It ends Nov 4th! )
    Whitehall, PA., U.S.A..
    I've covered my pool for the last 3 years and I tend to agree with the cover it till the leaves are done and then uncover it. This way you can still add bleach if you need to and circulate the water with a submirsabel pump. I see your in Ill. I remember some pretty warm spells late in the year so alge could still be a problem.
    The cover is nice because it keeps the light alge needs to grow down to a minimum.
    Don't know if this helps you any, just adding my 2 cents.
    Thanks Virangos. It does help. We didn't buy a leaf net, but I think we're okay because we don't have too many leaves. We'll just scoop it out as we see them. You're right about the Illinois weather. We've been in the 80's this week. We have not closed our pool yet because of that. We'll probably drain below the skimmer once the warm weather has subsided and then unhook everything and do the usual closing procedure except covering.
    I like to be able to add bleach since it won't be covered.
    Thanks again!
  1. Winter closing IG BBB Safety Cover - Best Chemical Balance prior to closing?
    By blue wolverine in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-16-2012, 04:36 PM
  2. Help w Chemicals for Above Ground Pool Closing
    By vlapinta in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-21-2009, 05:36 PM
  3. AGP Vacuum Suggestion
    By AnnaE in forum Above-Ground Pool Construction & Repair
    Last Post: 07-08-2008, 07:34 PM
  4. Plan on closing today, but read about polyquat dosage prior to closing...
    By The Raddish in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-06-2006, 10:50 PM
  5. need new filter.any suggestion
    By sisie5 in forum Pool Equipment & Operations
    Last Post: 08-21-2006, 10:33 AM
