Closed Thread
Thread: Over my head
    Default Re: Over my head
    I second the liner approach.
    If you decide to paint make sure you remove all loose plaster then patch those areas. You will also need to remove the old caulk between the concrete and fiberglass panels then recaulk. If you decide to put in a liner you will still need to repair all rough areas.
Closed Thread
