Thread: What chemicals are needed for closing?
    MD.
    Default What chemicals are needed for closing?
    First, thanks for prior advice. After my pool guy charged about $200 for chemicals to open, I learned from this forum, and bought my own chemicals for well under $100 this year.
    My pool is a little over 20,000 gallons, with a salt chlorinator, concrete gunite. What chemicals should I get for closing, and where is the best place to purchase them? Should I shock the pool with my chlorinator?
    Thumbs up Re: What chemicals are needed for closing?
    It all depends on what your current chem values are - could you please post the
    FC
    CC or TC
    ALK
    CALCIUM HARDNESS
    CYA
    You'll want to shock the pool (how much bleach you need depends on the CYA and % of the bleach) A lot of people add polyquat 60% for the winter - the bleach and the poly wipe each other out so shock first and hold it for a day or 2 then add the poly. (polyquat isn't required, but is a nice insurance policy against algae over the winter)
    What kind of cover do you use?
    $200 for opening chems is outrageous!! Unless your numbers are way out of whack and you're fighting algae ~$30 should do it
    Please let us know your numbers and we'll be able to tell you what and how much of each to add.
    Default Re: What chemicals are needed for closing?
    While Waste is correct, mostly you need enough chlorine to shock your pool.
    If you have lines than can collect water even after you drain them, you'll need pool line antifreeze.
    You may need to balance your pH with Borax and Muriatic Acid.
    I like to add a quart of PolyQuat 60% just before closing.
    But, unless you have a problem to solve, that's it.
    Me? It's usually just chlorine (IE bleach) and PolyQuat.
  1. Winterizing Chemicals Needed?
    By Steveromo in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-14-2011, 10:12 PM
  2. Help w Chemicals for Above Ground Pool Closing
    By vlapinta in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-21-2009, 05:36 PM
  3. fall chemicals needed
    By hannadock in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-10-2007, 10:38 AM
  4. Can someone take my hand after the chemicals and pool is clean on closing
    By traceyb in forum Above-Ground Pool Construction & Repair
    Last Post: 10-11-2006, 08:24 AM
