There are ways, I'm having to borrow a computer since mine is unusable right nowYou can use dye to check any suspect areas, if the dye gets sucked in, you've found the leak.
However, I'd double check the filter system first, especially a backwash line leak or something at the pump or filter!
I know others here can help, but it will be a few days before I can get my computer back on line (if I can) and find the info I've written on this - I'll check in as I can, but feel 'handicapped' by not having my computer.
