Re: How to find a hole in the liner?
My daughter discovered that if you lay swimming goggles on the surface of the water it magnifies the bottom of the pool. She walked around looking at the bottom and sure enough she found a small slice in the bottom about 1/4" an inch long. we patched it and the water leak slowed down so she started looking again and found two more. No more leaks and to think I was going to replace the liner.
vanman2501
