Thread: Pool Store Liquid Chlorine
    Michigan
    Default Pool Store Liquid Chlorine
    If I find a good deal on liquid chlorine can I still use the bleach calculator ?
    Rehoboth, MA
    Default Re: Pool Store Liquid Chlorine
    Yes, just make sure you adjust the chlorine strength accordingly in the calculator window (the pool store is probably 10.5 or 12% vs. 5.25 or 6% for laundry bleach). It's probably a good idea to check this every time especially if you will be using both throughout the season.
    Peter
    Katy, TX
    Absolutely. Just be sure to enter it as a regular number, i.e. 10.5% = 10.5 and you'll be all set. Personally, I loved using the liquid chlorine, it's just that it's hard to find a good deal on it. Also, it has to be kept inside, as warm temps degrade it rather rapidly.
    Michael
    Thumbs up Re: Pool Store Liquid Chlorine
    Quote Originally Posted by mwsmith2
    Michael
    Michael, and the rest of the forum, sunlight also has a VERY detremental effect on the liquid chlorine's concentration. If it comes in a transparent jug, store in a cool dry place. Just wanted to clarify for all (before their sodium hypo did )
    Upstate, NY (Dutchess County)
    Default Storage...
    What are acceptable temp/light conditions... I store my jugs of bleach in the garage but in the middle of July/Auguust it can get pretty warm out there (90*F)... But then again, that's hardly warm to those of you in FL, TX, AZ...
    26,000 Vynil Liner L Inground
    Hayward 1HP Superpump + Hayward Pro Grid 4800 DE Filter
    Poolvergnuegen thepoolcleaner Pressure Side Cleaner
    Loop-Loc Mesh cover
    Katy, TX
    Default Re: Storage...
    To me, acceptable is storing it in the house. I kept mine in the laundry room under the sink.
    Michael
