Thread: brown stain on fiberglass pool
    South Carolina
    Default brown stain on fiberglass pool
    We have a brown stain on our 10K fiberglass pool that has been there all season. When we opened the pool in the spring, it was a green mess. The cover must have had a leak that we weren't aware of. When we got all the green out, there was a brown stain left behind. We treated it with abscorbic acid this weekend, but it didn't remove the stain. Is there something else that we can use?
    Valerie
    Default Re: brown stain on fiberglass pool
    You can try a crushed up trichlor puck, or, depending on where it is, a magic eraser....if it's under the waterline, shocking the pool will sometimes remove it over time.
    Sacramento, CA, USA.
    One of the best products I have found to remove brown stains from a fiberglass pool is cal-hypo (calcium hypochlorite). If the stain is on the bottom, put enough in to cover the stain and let it sit. If on the walls, try to get a good amount on the floor just below it. Should be the answer.
    If you decide to do this, be very careful to either buy a small amount and use it all, or store the product very carefully. DO NOT ever mix it with any other product other than in the pool itself and always add the chemicals at different times or as far away from each other as possible. I have been using this product for over 15 years in the business and these are not suggestions. It is a very good product, but you have to understand the proper use and be aware of the potential for problems.
