Closed Thread
Thread: Is this correct
    Default Is this correct
    I am having a 16x35 pool buil. they are only putting in 1 skimmer and return lines are all on one side only. is this correct.
    Default Re: Is this correct
    What shape is the pool. My kidney pool 16X32 has two skimmers and two returns as well as a main drain in the deep end. The skimmers are positioned so that the prevailing winds during the summer blow the surface debris towards the skimmers. I would ask them to add another return and skimmer and make sure they plumb the skimmers independantly back to the pump and add a Jandy valve so you can adjust the flow through each.
Closed Thread
