Re: Help! didnt winterize before first hard freeze!
I'm not an expert on this but the obvious step is to act NOW!, TODAY! If the lines haven't frozen, blow them out and add the anti-freeze. If your skimmer has frozen but hasn't broken you'll want to pour warm water (not hot, certainly not boiling or it will crack) into it to melt the ice, then, if you have nothing else, stuff it with foam. If you have a kid's "noodle" float, sacrifice it for the skimmer.
Any pipes and hoses that can be disconnected, should be...I use quick connects EVERYWHERE so I can get rid of all the plumbing.
You'll want to drain your pool below the returns and skimmer. My rule is one inch below the return's bushing, not just the return itself. You can do this even if it's frozen--the water below shouldn't be.
For the buried pipes, the question is are they frozen or not? If they are, you'll have to get them unfrozen--and hope and pray they haven't cracked. But buried pipes take far longer to freeze, so there's hope, depending on how frozen and for how long it's been--is the ground that far down frozen?
You may want to buy a full-coverage wet suit--a thick one, with gloves, booties and a hood, just to be able to to the bottom where you need to, especially if you have a bottom drain. But do NOT go under ice--your pool isn't worth your life. Your pool's repairs will not compare to hurting yourself in personal cost.
Now let's hope the IG pool experts kick in with their ideas...I'm an AG guy.
