Carl has pretty much covered it. How much iced is on the surface? - this will be a good indicator as to the rest of the system. Open the pump and see if there is ice in it, if there is you'll need to cover the whole system and apply some heat to defrost it. As you just reran the lines, how deep did you run them? are they below the frost level?
If you remembered to run the pump when the temps were below 30* - the water should still be liquid.![]()
You've gotta do as much as you still can NOW! to protect the pool for the winter. If you need any more tips I'll check in every few hours to see if you've posted an update.
Good luck with this and the other stuff going on in your life
