Re: Progress finally, or The TA battle...
steveinaz
Ok, after multiple slams of acid this evening (and thanks to my waterfall for aeration) I've made serious progress in the battle of the high TA. Some numbers:
FC=5.5ppm
CC=0ppm
pH=7.5 (before slamming to 7.1)
CYA=90ppm (oops...updated reading tonight after 5 days of circulation)
TA=120ppm (uncorrected for CYA)...down from 180ppm 8 days ago
TA=93ppm (corrected for CYA)
CH=710ppm (yeah, yeah, I know. This is a battle for another day)
My grandmonkies will help me via "splashout" on the over-shoot of CYA, this weekend...plus, I have one of those pools that mysteriously looses CYA over the winter, so I'm not too concerned about it.
QUESTION EVAN:
Should I be looking at corrected TA for my target of 80ppm, or uncorrected? Uncorrected would make my target 110ppm TA...
I was gonna slam it one more time with acid this evening, but a 7.0-7.1 pH made me wait until tommorrow. I should be golden after that.
You want an uncorrected TA of 80 ppm or possibly even less with your waterfall if you are planning to add the borates, which I highly recommend.
Don't even mess with computing the corrected reading, it's just a waste of time.
Don't worry about the overshoot on the CYA. Even 100ppm is workable in Arizona with a SWG, especially given the high CH in that area, since it might allow you to run at an even lower output percentage and thereby get better pH control and thereby less chance of scaling conditions (particularly if you run the waterfall).
