Results 1 to 10 of 10
Thread: Bypass Valve On Heater
    Sacramento, CA, USA.
    Default Re: Bypass Valve On Heater
    Regular PVC does tend to start to soften above 90 degrees. If a spa is being heated, the water will regularly be above 100 degrees. Since there are so many different Mini-Max models, some with bulkhead fittings, some with cast metal headers, a good recommendation is to use a short section of CPVC on the inlet and outlet ports. I always do this on my heater installations and have never had an issue with the connections directly at the heater unless there is a malfunction in the heater itself. A couple of short pieces of CPVC (6"-12") does not cost much and is, in my opinion, worth the extra cost and effort.
    Unless you have a "fireman's" switch on your timer (for heating a pool) or an auto control with a cool-down cycle, most people will not cool their heaters properly after using them, especially with spa use. Even the retained heat in a newer heater and plumbing will eventually warp the systems plumbing if not cooled. Heater manufacturers say that proper cool-down can add 50% to the life of a pool/spa heater.
    Just Thursday had to re-plumb a system that was only 4 years old but had very regular spa use. It is a manually-controlled system and the customer said he was never told about cooling the system before shutting the pump down
    Just my experience.
    mas985's Avatar
    Pleasanton, CA
    Here are one set of pressure deratings for both PVC and CPVC. 2" schedule 40 PVC has a rating of 200 PSI at 110 deg F which much more than what is needed for a typical pool system.
    It is true that PVC is more easily deformed at higher temperatures but according to this reference, PVC really doesn't start to significantly soften until 54 degrees C or 129 degrees F and that is with a lot of loading. The derating for pressure drops much sooner but the rigidity isn't affected as quickly unless of course there is a large load on the pipe but given the short sections of pipe, it is unlikely that the pipe would ever sag.
    From my personal experience, I have never had a problem with heat deformation of the pipe exiting my heater. I also have had experience bending PVC pipe with a heat gun and you have to get it much hotter than what a heater could do before it even starts to bend.
    Mark
