Quote Originally Posted by kingbud
Yo Cary, you mean like, uh, just bleach, ya know, Clorox, Purex, etc? Wow, I must say that is pretty radical. Just buy it at the store and dump it in? Tell me more, please.
You know, this is our tenth year with this pool and the words Cyanuric Acid have never come up before now. Honest. I guess it's always something, nome thane?
Hmmmm... Last year I used a different algaecide for the first time, a product with kind of a hokey name, a very bold name if you get my meaning. I wonder if that stuff had anything to do with the sudden change in my water chemistry fortunes...?? On the other hand, the pucks themselves could be the problem, and perhaps the cyanuric acid has been building up over time. The current water is three years old - put in a new vinyl liner about three years ago.
Thanks for your comments, any other thoughts greatly appreciated.
nome thane?
King Bud:
Welcome to our forum with our "radical" ideas about pool care. Actually, when you LOOK at what we recommend, you'll find they aren't at all radical--they are simple, proven, and effective. I've learned to look at the ingredients on the label, not the big name.
Bleach: This is Sodium Hypochlorite solution--usually 5.25% or 6%. If you go to a pool store and for liquid chlorine or liquid shock, you will see it's the same stuff, but usually 6%, 10% or 12% concentrations--Sodium Hypochlorite and "inert" ingredients (basically water). Those big blue 5 gallon containers of liquid chlorine are exactly the same stuff--in 12% solution. So using bleach isn't radical at all--"A rose by any other name..." Pool store guys will give you an INCREDIBLE line of blarney as to why they are "different". They aren't.
Baking Soda: Sodium Bicarbonate. Arm and Hammer. But at the pool store it's called "Total Alkalinity Raiser" and it costs a lot more. Usually it says "Sodium Bicarbonate" as the key ingredient! Sometimes it says some other sodium compound, but it's just another name for bicarb. So why buy it there?
Soda Ash: "ph Up", "Balance Pak..." This is Sodium Carbonate, not Bicarb. It's sold as Soda Ash, Washing Soda etc. But PoolDoc has pointed out that chemically, Borax (20 Mule Team Borax) is just as effective for raising pH, doesn't increase Total Alkalinity as much, and is safer to handle. Both can come from the super market.
CYA: This is also called Chlorine Stabilizer, Cyanuric Acid, or Pool Conditioner. Chlorine (no matter where you get it--liquid, tablets, powder) will break down rapidly when exposed to UV rays, or lots of contaminants, sometimes, on a hot, sunny day, in as little as 15 minutes. CYA slows this process down keeping the chlorine around longer. This is a two-edged sword. You NEED CYA to keep chlorine stable, but too much renders it less effective--ie, it stops killing stuff and stops metabolizing suntan lotion and other contaminants. Then you need higher levels of chlorine to maintain your pool. When you use Tri-Chlor pucks or Di-Chlor powder, both release CYA as they dissolve. If your CYA is too low, this is good. But at some point your CYA starts to prevent your chlorine from doing its job. Sooner or later, using pucks, you will hit this point. We suggest levels of CYA from 30 to 50ppm but some people like to run higher levels--60-80ppm. That's OK, but you must keep sufficient chlorine in your water to match. PoolDoc has "Ben's Best Guess Table" that gives you levels that are recommended.
Happily, Bleach and liquid chlorine don't add CYA at all.
You have a vinyl liner--so calcium levels are generally irrelevant to you, unless they go 'way too high. So don't get talked into adding calcium.
Algaecide. I never bother to look at what they call it. Black Algaecide, Mustard Algaecide, whatever. I look for "Poly....<something unpronounceable>....60%. This is PolyQuat that we talk about. It's the only algaecide most of us will use. If it isn't PolyQuat, I suggest you trash it--it will probably do more harm than good. PolyQuat is safe, effective, doubles as a flocculent, and you can use it all the time--usually a couple of ounces every week to a clean pool is enough to keep it clean.
Hope this helps!
