New pump install problems-help
Well, I had to replace my ancient 1HP pump becuase the seal started leaking. I figured this was a good time to get a 2-speed model with a little more "oomph".
I bought a 2-speed Hayward Superpump, 1.5hp, and am having some issues.
Here are my pool specs:
25,000gal inground
single 1.5" suction and return
35 sq. ft DE filter (Pentair)
Pool Pilot Saltwater chlorinator
no heater
Polaris 360 pressure-side cleaner (runs off the main outlet, no booster pump needed)
I dont know the head of the system but there is not a long distance between pool and equipment, maybe 6ft on suction side and 20 ft from equip. to pressure side.
My reasoning for upsizing the pump was to get a bit more pressure for the Polaris unit, which could just barely run adequately off my old 1HP pump. I figured when not using the cleaner I would just run on low speed, so the 1.5HP upsizing would not be a problem.
I respositioned the new pump for easier access and in the process had to plumb 2 extra 90 degree elbows into the suction line (imagine a big "U" shape from where the suction exits the ground to the pump inlet).
So now I have 3 separate problems- maybe all related.
-pump works but on low speed not enough flow to run the saltwater chlor. cell (shuts off on low flow).
-on both speeds there are a ton of little bubbles inside the pump trap, a few issuing out of the return line, and on low speed there is a big air pocket at the top of the pump trap that never goes away (I verified there is no suction leak, the pump holds a vacuum and a full trap full of water overnite too).
- after a few hours of running there is now an abnormal mechanical sound (like a hissing or buzzing) really noticeable on low speed. Sounds like the impeller is rubbing the inside of the housing or maybe a bad bearing. Doesnt really sound like what I imagine cavitation would sound like.
On the good side on high speed it does run my cleaner quite well (cleaner needs about 20 psi to function right).
So I think I need to do 2 things, in order of importance, to fix the problems:
1. Orient the pump just like the old one and get rid of the 2 extra elbows and extra distance in the suction plumbing
2. Try to get a 1HP version of the pump, and return this one due to the (impeller, bearing?) issues.
3. Hope that when everything is plumbed right, the low speed can run my SWG OK, otherwise I guess I will just run on high speed all the time.
Am I on the right track here? Is my pump cavitating? I would expect a "pebbles in the pump" kind of noise in that case, but the bubbles in the trap combined with no suction leak have me wondering. My old pump never did this, and ran the whole system OK as long as the filter was relatively clean.
