Thread: Hayward Filter - can a heat exchanger be replaced?
    Smile Hayward Filter - can a heat exchanger be replaced?
    Couple years ago our Hayward H250 started leaking (due to chemical issues with previous owner) I pulled it out of the line and we have gotten along just fine. Well it is still just sitting there and either I need to fix it or get it hauled away. Is it possible to order and install a heat exchanger ourselves?
    Thanks so much for your help and idea's.
    Default Re: Hayward Filter - can a heat exchanger be replaced?
    The heat exchanger can certainly be replaced! It's about the most expensive part of the heater so you may want to consider a new heater (the company I work for is currently installing mostly heatpumps - it may well be worth your time to consider a different type of heater vs. replacing the exchanger)
    If you have further questions, I'm here almost every day and always check my PM's
  1. Hayward Heater - repairing the heat exchanger
    By Jake_2012 in forum Pool Equipment & Operations
    Last Post: 07-23-2012, 11:14 AM
  2. Replaced Hayward Heat Exchanger HAXHXA1253 - Noticeable smoke from heater
    By kersten in forum Pool Equipment & Operations
    Last Post: 01-22-2012, 12:28 AM
  3. heat exchanger
    By essikr in forum Pool Equipment & Operations
    Last Post: 05-09-2011, 06:57 AM
  4. heat exchanger fixable
    By markginger in forum Pool Equipment & Operations
    Last Post: 04-23-2007, 11:52 PM
  5. Wood heater with Copper heat exchanger
    By goosegunner in forum Pool Equipment & Operations
    Last Post: 07-07-2006, 12:55 PM
