Results 1 to 8 of 8
Thread: Stupid question?
    Sacramento, CA, USA.
    Default Re: Stupid question?
    Take it apart again and try to see if any of the white hoses inside have come loose. This is the water management system. If they have, or if the wire-tie clamps have broken, you will have problems. Putting the hose(s) or clamps back on will require a much more extensive tear down.Its not easy, but it can be done.
    The only stupid question is: I put it all back together, but I had these extra parts...do I need them?
    Carl, In your case, no!
