Results 1 to 10 of 11
Thread: Full opening instructions?
    Default Full opening instructions?
    I want to open my pool myself this year instead of the usual $300-400 pool company charge. Is there a step-by-step guide? I've seen several things about water chemistry, but what about the sequence of steps for the pump, filter (DE), heater (gas), etc?
    Charlie
    Default Re: Full opening instructions?
    Trouble Free Pool has the Pool School post Opening Your Winterized Above Ground Pool and The PoolForum (this site) has FAQ: Common Spring Startup Problems (initially had a typo as "FAQ: Common Sprint Startup Problems").
    Hope that helps.
    Richard
    Actually, it's SPRING Start up Problems, not Sprint. We don't do cell phones here--try Howardsforum.com for that
    Carl, cut Richard some slack! He has probably done almost as much for us singlehandedly as Ben has!
    I can take a tease! I've corrected the offending misspelling above.
    Evan, thanks for the compliment. I may have depth in pool water chemistry theory in some narrow areas that Ben did not, but he had breadth and experience that is unmatched. I miss him.
    I was referring to the behind the scene work you have been doing on the new standards for pool watern that you have alluded to at times.
    Heck, Evan, no wunder! Yoo kent spel two gude eether
    (besides, I only make fun of friends--I'm sarcastic and belittling to all others!)
    So is that making fun or being sarcastic and belittling?
    (And did you ever think that I might have misspelled on purpose!)
    You'll never know!
    You'll never know!
    Neither will you!
  1. How full is full on an easy set pool?
    By Larryh86GT in forum Intex-type Pool Setup & Operations
    Last Post: 06-28-2013, 11:02 PM
  2. Help with test kit instructions
    By kevincad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-12-2007, 11:33 PM
  3. Leslie's (Same as Poolmaster?)OTO Kit - Need Instructions
    By pspercy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-12-2006, 02:56 PM
  4. Where are the instructions for PS234
    By ksturge in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-05-2006, 10:44 PM
  5. Need instructions on opening a pool
    By littleHeidi in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-12-2006, 10:38 PM
