Ok I have two issues with my Aquarite SWG. First I have small bubbles coming from my return lines when my Aquarite is generating. I have heard this is normal but wanted to see if any of you have had the same issue.
The second and more irritating by far is that the Aquarite also seems to be producing little milky white flakes. Has anyone had this happen to them? The flakes are small and pretty much disolve or break up if you pick them out of the water. the problem is that there are sooo many of them. I love to have crystal clear water and it stinks to have all this stuff floating in my pool. Could it be the salt I used? It was the Mortons in the big yellow bags that they sell at Home Depot.
Any help is GREATLY appreciated.
by the way my pool is a 14,000 gal. inground pool with the 3M Colorquartz plaster.
I just sent an e-mail to Aquarite tech support to see what they had to say about the flakes.
. With fill water over 350 ppm hardness, it is very difficult to keep the pool below 400 ppm. The only thing I have to work with is alkalinity and PH and that does not seem to be enough.
- seriously, Sean, as per usual, has the right take on this.
