Thread: Salt at 5400
    steveinaz is offline Lifetime Member Weir Watcher steveinaz 2 stars steveinaz 2 stars
    Southern Arizona
    Default Re: Salt at 5400
    Salt does not dilute, did you have to drain because of excessive rainfall?
    Draining is the only way to lower it now. Are you using the taylor salt test kit?
    Normally, due to splash-out (I have grandchildren), and draining because of monsoon rainfalls--I have to add about 4lbs each season to my 12,600 gallon IG.
