Results 1 to 9 of 9
Thread: PANIC...or not! Need help asap...I think.
    rnjng Guest
    Default Re: PANIC...or not! Need help asap...I think.
    Thanks for the Ideas!!!!!!So it is fixable.? The liner is more than i season old. It is still cold out here in NW indiana so the liner is not to strechy. will it be ok to wait till it gets warmer to remount? or will it be too late by then. About 6 more weeks till consistant warm weather( I hope).
    Looks to be a beaded liner. There are some tips and tricks in the stickie at the top of this section. Are those the only 2 sections?
    If you can get the center of each section in, the rest will go in easier If you have to work from the edges to the center, watch out for blisters and that you pull the liner STRAIGHT! up or you could end up with extra liner (too much to get in the track) when you get to the middle!
    If you are having any trouble when it comes time to get the liner back in place, post it here and we'll help as we can
    rnjng Guest
    OK, so the liner came loose on more than half of the pool wall, and about 3" of water is in the pool now, about 2/3 of the pool has water on the pool floor. Pool is(obviously) not level. The other 1/3 has no water. Can I still remount the liner and use it? Or should we replace it? Really don't have the $$$ for new liner hope we still can use it. Thank you again.!!!!!!!!!!!!!
    rnjng Guest
    Anyone??? Can we reuse our liner? Or need a new one.
    Honesdale PA
    No way to tell. Only thing is to try and if it's destroyed you're no worse off.
    rnjng Guest
    good enough for me! We will give it a go. TKS!!!
  1. Help..tear in vinyl liner at rope attachment ring....panic!!
    By heatherc in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-16-2012, 07:23 PM
  2. Step stains help asap
    By romeomontego in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-05-2010, 01:10 AM
  3. Need the Filter experts help asap?
    By mjs31 in forum Pool Equipment & Operations
    Last Post: 10-17-2007, 07:34 PM
  4. Need help asap (pool pump)
    By ellenicol in forum Pool Equipment & Operations
    Last Post: 06-30-2006, 10:43 PM
