Results 1 to 9 of 9
Thread: PANIC...or not! Need help asap...I think.
    rnjng Guest
    Default Re: PANIC...or not! Need help asap...I think.
    OK, so the liner came loose on more than half of the pool wall, and about 3" of water is in the pool now, about 2/3 of the pool has water on the pool floor. Pool is(obviously) not level. The other 1/3 has no water. Can I still remount the liner and use it? Or should we replace it? Really don't have the $$$ for new liner hope we still can use it. Thank you again.!!!!!!!!!!!!!
    rnjng Guest
    Anyone??? Can we reuse our liner? Or need a new one.
    Honesdale PA
    No way to tell. Only thing is to try and if it's destroyed you're no worse off.
    rnjng Guest
    good enough for me! We will give it a go. TKS!!!
