Results 1 to 10 of 34
Thread: Weekend Baquacil Conversion
    b2001 is offline Registered+ Thread Analyst b2001 0
    Dallas, Tx
    Default Re: Weekend Baquacil Conversion
    An update on my progress ...
    I have been getting frustrated at my progress. The pool is still green and cloudy; it seems to have improved a little today. Here's what I have done:
    I'm either putting in 4 gallons of 5.25% bleach or 3 1/2 gallons of 6% bleach ...
    Put in one dose Saturday at dusk, Sunday at dusk, Monday at dusk. After watermom's Sunday reply to this post and duraleigh's last reply to the "Softswim to Chlorine Conversion??" post, I stepped it up today, a dose at dawn and will do dose at dusk.
    I'm cleaning my cartridge filter and skimmer basket sock 2 to 3 times per day. Both are definitely orange-brown when they come out for cleaning. The filter in there now is relatievly new and pressure is currently at 10 psi. When it climbs to 20 psi, I don't get very good results.
    I've vacummed my pool several times and I scrubbed the walls and and all of the floor thoroughly Sunday and yesterday. The floor feels ok are far as trash goes, except I didn't go into the deep part, an area of about 10 feet by 10 feet which is about 1 1/2 feet deeper than the rest of the pool - I was too much of a chicken yesterday to go completely in the cold water. Of course, most of the trash settles there, but I believe that I have done a decent job of getting most of it. The pool is still cloudy and green enough that I can't come close to seeing the bottom of the deep end. I barely cannot see the bottom everywhere else.
    No one is really home during the day - can I go ahead and get chlor-tabs to supplement the bleach process for during the day? Where should I look to buy and what brand should I look for ro avoid? The local pool place has a small container for $30.
    My pool was green before starting the conversion. Will a bottle of polyquat algeacide help now?
    I tested about 30 minutes ago:
    OTO
    Cl between 0.5 and 1.0 ppm
    ph between 7.2 and 7.5 ppm
    DPD
    free cl is 0.5 ppm
    total cl is 3.0 ppm
    ph is 7.4 ppm
    ta is 100 ppm
    cal hrdness is 110 ppm
    Thanks for any replies ...
    I don't think the tabs are going to help. You need to shock the pool and tabs aren't going to give you that shock. Can you shock it as soon as you get home in the evening and then again right before you go to bed at night and then again in the morning? Then, on the weekend, really hammer it with bleach as often as you can. Someone may have a better idea, but that is my suggestion. Algaecide isn't really going to do anything for you at this point. Keep your pump running 24/7. Hang in there.
    mjones is offline ** No working email address ** mjones 0
    Mississippi
    OK, I just put 8 lbs of shock in pool(bottle says 56% available cl). It already looked a tad bit lighter shade of green, but that could be because we added more water. I am not sure about the CL level. I have tried strips & oto. Strips say hardness about 100, total cl 5 ish, f cl way over 10, ph 6.2-6.8, alk 80-120. I can't understand the oto. tried the diluting thing, oto said +3 cl? I don't know.. I am confused & to the point that I just want to keep putting cl in every 8 hours or so. Hoping it will clear up soon.
    I bought 4 gallons of plain ole bleach, 1 1/2 gal of clorox "outdoor"?, says it makes up to 30 gallons?? and the 8 lb bottle of shock. The bottle of shock said not to mix with cal hypo?? what does that mean?
    mbar's Avatar
    Ashland, PA
    Your ph is really low, I would add a box of borax asap, test after 2 hours, and add more if needed. You don't want your ph below 7, that could damage your liner. Chlorine is more potent when the ph is low, but you shouldn't let it get lower than 7.2 on your test, because the ph may be even lower than the test shows sometimes.
    Northeast PA
    Mississippi
    Not much difference this morning. I just added 4 gallons of 6% bleach. I was wondering if I need to go ahead & change my sand, because of psi so high, & skimmer isn't sucking very hard.
    Mississippi
    what do you mean by "damage" my liner? Re: my low ph?
    duraleigh Guest
    mjones,
    You would do much better to start your own thread so you can get the help you need.
    You will not have too much luck testing with strips. post your test results from a drops-based kit and we can give you help.
    That "outdoor" Clorox you used is not wise....you are putting stuff in your pool that is not helping you....post for FC, CC, CH, pH, Alk, and CYA.
    does the sand in the filter need to be replaced when this is all said and done?
    duraleigh Guest
    Watermom is right about the poly.....don't waste your money.
    YOU NEED MORE CL!!!! Sorry to shout but I want to make a point. Look at your Cl readings....not enough for even maintenance on a pool already clear!!
    Try this stategy...If the direct sun is off your pool an hour before sundown, put in enough Cl to go to 16ppm. Remember it's gonna go down immediately...it may never even get to 16. Now go out just before you go to bed, test, and bring your Cl back up to 16ppm again....I'll bet you need to add a lot.
    If you wake up around 4:00AM, you can do it again. If you wake up after sunrise, any Cl you put in will be quickly consumed.
    You have got to repeat this pattern each evening. If you let your Cl slip back to it's current level......you get no results......that's where you are now.
    Keep the faith and understand the process.....You are burning Cl at a rapid rate and you must keep it up there or you languish.....and get no progress.
    Your other numbers are fine....you need Cl.
    Have I mentioned you might add some more Cl?
  1. Baquacil CDX to Chlorine conversion
    By gbwarrior in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 02-07-2012, 03:59 PM
  2. Baquacil Conversion
    By duckmka in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 04-20-2007, 09:26 PM
  3. New Sand after Baquacil Conversion
    By lizzie64 in forum Pool Equipment & Operations
    Last Post: 07-06-2006, 09:25 PM
  4. Baquacil Conversion Done, Now what
    By bcpoolowner in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-22-2006, 12:13 AM
