Not much difference this morning. I just added 4 gallons of 6% bleach. I was wondering if I need to go ahead & change my sand, because of psi so high, & skimmer isn't sucking very hard.
what do you mean by "damage" my liner? Re: my low ph?
PH readings below 7.0 are acidic and thus can damage the liner.
mjones,
You would do much better to start your own thread so you can get the help you need.
You will not have too much luck testing with strips. post your test results from a drops-based kit and we can give you help.
That "outdoor" Clorox you used is not wise....you are putting stuff in your pool that is not helping you....post for FC, CC, CH, pH, Alk, and CYA.![]()
