Re: adding muriatic acid to covered swg pool
Welcome to the Forum! I live in your area and have a similar pool, including lots of trees, but I don't have a safety cover. Once the main leaf drop has finished, I leave the pool uncovered. When the temp gets to 55, I turn off the SWG and just run the pumps 2 hrs each day to work the pool cleaner. That said, if you adjust the pH a couple days before turning off your SWG for the winter, it should be good for quite a while. I might check the balance again in January to see if any adjustments are needed. I think peeling back a bit of the cover is your only application method that I know of.
As for actually adding the acid, pour it in over a return in the deep end, preferably one that is pointed a bit toward the main drain. Make sure the pumps are running as you pour it in and put the main drain on heavy suction to reduce the chances that any of it will pool at the bottom. In this scenario I don't think there's much chance of that happening, especially if you're only adding a cup or two to 20,000 gallons.
By the way, my boys and I swam yesterday! I've had a solar cover on it for the last three weeks and, boy, did it make a difference!! The water was nice and warm...for the first 4-5 inches.
Then it was.......BRISK!
Have fun. I hope this helps. I can't help with the 'whys' of SWG pH rise. Maybe Chem Geek will chime in.
Hal
