Thread: Autopliot SWG problem after refill
    Honesdale PA
    Default Re: Autopliot SWG problem after refill
    Just a shot in the dark since I never played with a SWCG but what if you took a sample right at a return jet at full power then another with it off and see if there is an FC difference ? I would think the Cl concentration at the jet would be high enough to see if the generator is at least working....but maybe not.
    Saint Cloud, FL
    Bringing down the TA is a long drawn out process. (See the Sticky in Alkalinity and Calcium Hardness by Pool Doc)
    I would continue adding chlorine to help the SWCG as much as possible, and carry on aerating with the pH down to 7.0 - 7.2. the pH will continue to creep upwards, because of your plaster pool and the TA, so it's PITA you have to endure until your pool chemistry settles down.
    Poconos, it should be possible to check the DC amps on the DG-220 Controller, and if it is low, (<4 amps) I would check the cell for any scale build-up, and clean with 20% Muriatic acid.
    Let us know how you make out.
    Pat
