a couple of observations:
did you check your TA?
A full set of test numbers would be helpful here.
also, it would have been a better idea to adjust pH and TA before you shocked because high chlorine levels will cause the pH test to read high when it is not. Your pH is a LOT lower than you think and I will bet that your TA is around 0 ppm. Have you been using trichlor? That is the usual culprit.
We switched from Bleach and Borax for like 5 years to using 3" tabs last summer. They saved us lots of money vs. just bleach alone, so we are sticking to that route.
