Re: Will 1.5 HP Pump 80 Feet (Solar Heater)
I'm not the pump expert but I think it should be fine, if the pump roof isn't too high. I have solar panels and a 1hp on a 40x16, but they are only about 4-5 feet above the pump.
If the 1.5 hp is full-rated, you definitely should be OK. There may be some plumbing issues, but that's better handled by some other people.
