Results 1 to 10 of 12
Thread: 1st test results of spring - few questions...
    court475 Guest
    Default Re: 1st test results of spring - few questions...
    Thanks for the advice! Maybe I'll just get some tri-chlor tabs and make it easier on myself. Do you know how many I should add? I've never used them.
    Marion, OH
    First outbreak of warm weather here in Central Ohio this weekend - decided to open the pool yesterday morning. We've been using the BBB method for 2 years now - and we could see the bottom of our 10,000 in-ground immediately after taking the cover off! Vacuumned and started dosing it with 2 gallons of 9.5%. Added 2 more gallons last night after dark.
    Here are my readings this morning: (I purchased a TF-100 over the winter so this is my first testing)
    FC = 4
    CC = .5
    Alk = 130
    PH = 7.5
    CYA = 0 (every spring we end up with 0)
    Salt = 1810 (no, we don't have a SWG, but after reading this forum we added water softener salt last year (80 lbs) - the water feels much better !)
    Water is clear, but not crystal clear yet. Planning on adding 1/2 cup of DE to my sand filter today, and about 1/3 of what I think I need of stabilizer.
    Just another testament to the beauty of this method. So far we have spent $20!
    Any suggestions?
    Quote Originally Posted by court475 View Post
    I SHOULD know, but I can't remember the break-out.
    I actually rarely use them, always relying on separates.
    You'll need a lot initially, but when your pH levels get into the 7's you'll want to cut back. When your CYA level reaches 50, you'll probably want to stop and return to bleach, but there are situations where a higher CYA is preferable, like hot humid environments like aylad's Louisiana.
    Marion, OH
    I also should have added to my post above that last fall we followed Carl's instructions TO THE LETTER on closing our pool. Had the cleanest opening this year that we've ever had. Thanks, Carl.
    And I doubt we'll be swimming soon - it is Ohio, so today the high temp was 62.
    apopka, florida.
    Thumbs up Re: 1st test results of spring - few questions...
    Glad to see everyone back. I lost the address a while ago after I got no response to normal attempts to connect. I just got my annual "Happy Birthday" so I knew you were alive.
    My pool lives on tri-chlor tabs in a Hayward feeder and Borax. I insisted on a DE filter when it was built, had pools before and they are the ONLY way to go for clear water. I think I still have the bottle of acid the builder left with the pool 4 years ago, don't know, really haven't looked for it.
    Live in central Florida and pool was 84 F. last weekend. Grandkids were in the pool all day. I couldn't believe how clear the water was. My daughter has one of the new digital underwater cameras and the pictures look like they were taken outside on a very clear day.
    Again, glad to see you back and will be a frequent reader/poster.
    Hi mscans and welcome to the forum! Just wondering if you keep a close eye on your cya level since you say that your pool lives on trichlor tabs. Using those tabs exclusively will cause your cya level to rise to an undesirable level. Do you know what your cya reading is?
    court475 Guest
    Well I used 7 TriChlor tabs (the whole bugget - $20) and I'm still at 0 CYA and Cl. Guess I'll try the straight CYA. Ph wasn't really lower either. MAYBE 7.8.
    To raise your CYA quickly enough to get "some" in the pool, go ahead and use straight CYA--I would target about 15-20 ppm when figuring how much to add. Then you can use the trichlor from there until it gets to where you want it. As far as pH goes, the trichlor WILL bring it down, and 7.8 isn't too bad to begin with so I wouldn't worry about that.
