Thread: When to add sand
    Default When to add sand
    I have had my pool for six years now. I have learned so much from this site. In fact, I have never had a problem I couldn't get solved by reading the forum. Now I am wondering when I need to change sand in my filter. I have cleaned the sand in the fall each year with the product recommended by the dealer. But my sand level seems to be getting lower. And it looks really gross. Also, why do pool owners add DE to the sand? What is it and what does it do? Thanks, Dorie
    Honesdale PA
    Default Re: When to add sand
    Hi Dorie,
    Theoretically you should never have to replace the sand. Only reason should be if you really gunk it up somehow such as doing a baquacil conversion. If it looks gross to you just try removing the top layer. Maybe an inch or two and replacing that. Every time you backwash you do lose a little so that will explain why the level drops. The depth of the sand isn't critical but the surface area is and that doesn't change for a given filter. Since you're into it then fill it to the recommended level.
    DE powder is Diatomacious (sp) earth which is a really fine filter powder. Much finer than sand so if you throw a little in the skimmer it will coat the top layer of sand and catch finer particles. Most people don't do it but some of us do and it does improve the water clarity somewhat. We add slowly, about a half cup at a time, and let the pump run for 15 minutes or so and note the pressure. Shoot for about a 1 psi pressure increase. Mix the DE in a bucket of water and pour that in the skimmer. Also, don't breathe the dust. Be aware that the filter will tend to plug sooner that with plain sand so keep an eye on your pressure until you get a feel for the behavior.
    Check these threads:
    http://www.poolforum.com/pf2/showthread.php?t=3742
    http://www.poolforum.com/pf2/showthread.php?t=6744
    Any more questions, just ask.
    Good to see the activity picking up after the Winter.
  1. replaced sand and now sand is entering pool
    By flomenhoft in forum Pool Equipment & Operations
    Last Post: 07-21-2012, 01:29 PM
  2. Sand Filter dumped all the sand in my pool
    By ib_gman in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-15-2012, 01:16 AM
  3. Sand Filter Sand amount question
    By kevincad in forum Above-Ground Pool Construction & Repair
    Last Post: 07-04-2008, 09:36 AM
  4. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
  5. Jacuzzi ST-24 sand filter - sand in pool
    By ksturge in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 09:58 AM
