Re: Heat Pump in the New York/North East Area Make Sense ? Survey Please
Really don't know what to tell you except a few general things. The $1800 sounds real steep for laying a pipe. Code probably says gas pipe has to be at least 18" down. You could rent a ditch witch and do the trenching yourself. Once the ditch is dug then get a bunch of sand and lay a couple inches in the trench, lay the pipe, then a couple more inches of sand then refill. Sand protects the pipe from rocks and so forth. For a run that long the pipe diameter is probably over an inch because of the distance you have to flow low pressure gas. There are tables for this info. This is what I did when I had a propane heater but then again, no codes at my place.
As for the tradeoff of propane vs. heat pump, I have no idea. All depends on propane cost and electric rates. You're pretty far north so a heat pump for heating a house in the Winter probably won't make sense but for a pool you're adding heat when the outside temperature is high so the heat pump efficiency is high. I have no experience with heat pumps for pools.
Hope this helps a little.
Thanks Poconos. The $1,800 was made up of approx. $750.00 to dig the trench and the remainder for the propane co. to lay the pipe and price of materials. Yes, code in my town requires 18" trench, backfilled with suitable sand/pea gravel. Likely, a lot of rocks to contend with in digging the trench. Besides the long run, there is also a significant elevation change as the pool area is terraced below with RR tie retaining wall. I believe this also requires certain "modifications" in piping dimension. I am hoping to be comfortable going with the Heat Pump, but waiting to see how people respond to post.
The other question that comes to mind is are you planning to use your pool everyday or leave it for a week or more at a time. For everyday use you'll probably want the heat pump since it's supposed to be far less expensive to run on an everyday basis. But if you have to heat the pool up because it has sat, then gas may be the way to go.
Have you considered solar? You said you have a great deal of sunlight. Trust me, it works where you live. I give this as an example:
My parents had an 18x33 oval 4' deep. I installed a 4x20 and 4x10 panel for them--just the two panels. Their pool (and the panels) only got 6 hours of direct sun a day (too many trees), yet the pool which NEVER went over 80 in years past, stayed at 84 all summer.
The kicker: their house is in Ossining. That's Northern Westchester.
Thanks CarlD. This is my primary (and only) residence so the pool will not sit idle. The idea is to make it warm enough to really make good use. I am a lap swimmer and would love to try and get in almost every day.
Ahhhh .... solar. Now why did you have to complicate my choices -- and Ossining is approx 15 min. from me ! Several people have suggested solar, but I guess, I mentally pushed that aside because I was pulling my hair out with only two choices. Also, my house sits terraced above the pool which is probably 10 feet below. Between the house and the pool is a two tiered 8-10 foot railroad tie retaining wall. Thus, I envision another difficult process to pipe it up to house and down to the pool. Dont see how to add a photo to the post, otherwise I would show you what I am up against and no we didnt build the pool, it was preexisting at the house we purchased approx. 4 years ago.
How much for a solar system to suit my needs, with or without labor ?
Thanks again for your help.
About the solar...all it takes is a south, or somewhat south, facing area and as much space as you have. I have a back field about 70' from the pool that is unmowed. Laid out 1200' of black poly 1/2" pipe on rolled shingles to give the pipe a black surface to sit on. Total area is about 8' x 50' and it could be shrunk if more effort was put into laying the pipe. When the grass grows you can't even see it. Pros about homebrew, cheap. Cons, not as efficient as a mat heater.
Unless you use something like photobucket you can't post pics on the forum. Even we mods can't. Bah!
Thanks Al. Unfortunately all the sun I get is on an east/west facing roof. I have NO south facing roof and no other area to lay out such a system.
Panels can be set on angled racks--they actually face the sun better. I have a FantaSea pool--the deck is the solar heater!
