Thread: inland hurricane victim
    Carterville,IL
    Thumbs up Re: inland hurricane victim
    no, havent checked #'s yet. Bought a new heavy duty algaecide 2000 from my pool supplier, said it was 100% algaecide, good stuff and he told me to put 2 chlorine tabs in. So far the water is 10 times better, light blue/green now. She doesn't like to shock until the water is stabilized. I thought different, but he has always done the trick! Using minimal chemicals/$. I vacuumed 98% to waste and thankfully mother nature has helped replenish the water i've lost. Now I probably shouldn't vacuum any more to waste as I would loose the algaecide that I put in it! Thanks for your input, I welcome more if you have it.
    Great day!
    30' Esther Williams Classic Granite
    Installed july 2006
    Default Re: inland hurricane victim
    Reread Jan's post above. She is right on the money as always. You need to shock to clear the pool. Using tabs is not going to be a very effective way to maintain your chlorine at shock level right now. Better to use bleach now and then when you get the water cleared up, you can switch to trichlor tabs ---- if your cya level allows it. Good luck.
    Carterville,IL
    Question Re: inland hurricane victim
    Ok, The water is clear, but looking from a distance, there is a slight green tint to the water. I have a drop kit and here are the readings
    Chlorine is ideal
    pH is 7.6 slightly above ideal
    and the alkalinity is 130
    Am wondering if I need another hit of algaecide since the chlorine is where i need it.
    Any suggestions?
    Installed july 2006
    We have NO idea what "Chlorine is ideal" means. If you are using an OTO drop kit you may have a scale that indicates 1.5-2 is "ideal" and 3 is "high". This is terribly wrong for most pools.
    If you don't have a FAS-DPD test kit, you can have a pool store test a sample. They'll then tell you that you need $100-$200 worth of chemicals, especially calcium (useless in an above-ground vinyl pool). Tell them you have to check what you have at home....
    What we need to see is:
    FC (free chlorine)
    CC (Combined chloramines) or TC (Total Chlorine)--either is fine TC= FC + CC so you can figure it out.
    CYA (Stabilizer or Cyanuric Acid)
    Hardness is a waste of time unless it's high,
    metal contents can be useful.
    Your pH of 7.6 is actually perfect. Don't mess with it.
    TECHNICALLY, your alkalinity is a tad high, but in a vinyl pool you shouldn't have to worry until it hits 200ppm--so don't worry about it.
    But the FC, CC and CYA numbers are what we need.
    The BEST would be FC positive, CC=0 and CYA at a level where the FC is effective.
    I suspect you still have algae if you have a greenish tinge to the water. Depending on your CYA number you'll need to add chlorine to bring it to that CYA's shocking number. Look at Ben's Best Guess table to see the ratios.
