Results 1 to 4 of 4
Thread: Changing Filters
    Connecticut
    Default Changing Filters
    I would like to change my current filer (cartridge) to a sand filter. I am starting my 4th year with the current cartridges and they need to be replaced so I figured that now is as good a time as any to switch. The cleaning isn't so bad its just putting the filter back together is a PIA - came home one day and found I lost a couple thousand gallons of water cause the top of the filter wasn't positioned perfectly & this was 2 weeks after I cleaned the cartridges - never the less I want to switch to a sand filter
    Here are the pools stats:
    Pentair Clean & Clear Plus 240
    Pentair Whisper Flow 1.5 HP - Single Speed
    18,000 Gal
    Run the pump about 10 hours /day
    The current filter is rated for 90 GPM does the new filter have to meet this?
    Current filter is 2" PVC any problem going to 1.5" connections on the new filter?
    Was considering HAYWARD S244T PRO SERIES 24" any thoughts?
    Thanks for any help you can provide
    Default Re: Changing Filters
    Upsizing the filter NEVER hurts!
    Please do yourself a favor and be sure to get a 6 position multiport, not a push/ pull valve nor a 4 position multi!!
    Connecticut
    Waste - Thanks for the reply - The filter I am looking at has a lower flow rate should I be concerned? should I be looking for a sand filter with the same flow rate as the Catridge filter I currently have?
    Thanks - Jeff
    I don't have the specs for the filters handy but it's a good idea to keep the flow trough the filter LOWER. Think of it this way, lower flow through the filter lets more debris get trapped (ie. not just blow through the filter media).
    I'm pretty sure the S - 244 is a decent match for a 1.5 hp pump but.. it never hurts to get the next size up filter
