Heater won't fire
Hello,
I have a Pentair MiniMax 400 electronic ignition heater. I went to run the spa for the first time this season. It fired off OK and all the burners were flaming properly. It would run for a few minutes then knock off. I would toggle the switch a few times, it would run a few minutes again, and I would repeat the process. Then finally it ran fine for over two hours and quit again and now it doesn't even click. Any thoughts, as to where to begin. Oh, one other thing, the switch rocker that rocks from pool to spa now only works on the pool side. When I throw it to the spa side, the lights don't even go on. So I'm wondering if it could be something in that assembly. Although I have aremote Jandy system, so I'm not sure is that switch even plays a part or not, since with a remote system I never use it to operate tha heater.
Thanks in advance.
- You may not post replies
- You may not edit your posts
Forum Rules
