Results 1 to 10 of 13
Thread: skimmer leak
    Joliet
    Default skimmer leak
    Hello all
    Being new to this forum, and to pools, I just wanted to say hello...and thanks for a great site!
    I just had our pool installed by a professional company, hired thru the place where we bought our pool. Yesterday I finally got done filling the pool. Once the water was up to height and above the skimmer plate, I noticed that there is a small drip coming from the skimmer plate on the OUTSIDE of the pool (about one drip every second).
    I've got a call into the installers, but was wondering if there is anything I could do to fix the problem. So far I've tried tightening the screws on the skimmer plate (inside of pool), but all were tight. Is there anything else to try?
    Thanks,
    dan
    Default Re: skimmer leak
    I would have 2 thoughts:
    1) Pool epoxy around the rim of the skimmer INSIDE the pool to seal it--but I don't think I'd do this on vinyl.
    2) Lower the water till the skimmer is dry and replace whatever is broken--either the frame or skimmer is cracked or the gasket is torn or crimped.
    You don't want to seal it from the outside--that will cause water to back up and rot the walls.
    Joliet
    Thanks for the advice. I think it may be the gasket. I'm going to see where I get with the installer/pool place...but I don't want to let things go for too long.
    I'm certainly excited to get the water up and going. I've got Ben's kit on urgent pre-order, so I could get things ready soon I also disconnected my nature2 system (that came included with the pool). I'm sure I'll have plenty of questions...but would first like to get Ben's kit and post with some numbers first.
    Thanks!
    dan
    Joliet
    Still no word back from the company that installed my pool.
    I'm guessing that the problem is with the gasket. Iwas looking at the pool store and the gaskets are fairly cheap. So I'm thinking of draining the pool below the skimmer line and changing it out.
    My question...
    Because the skimmer was put in when the water level was below 1 foot, do I have to worry about the liner coming displaced downwards once I remove the skimmer? (did that make sense?)
    thanks,
    dan
    I would think your liner has stretched in by now and it should be fine.
    It is very possible the gasket just needs to be adjusted a little. Being a new pool it probably does not need replaced. On a couple occasions I have had to go back and do this. I prefer working with a full pool. That way I can see the results without having to wait.
    It is usually a case where the gasket is not pushed down far enough at the bottom. It is very easy for this to happen. I would loosen all the screws slightly and then remove the bottom ones. You may need to go up the sides or you may not. You should be able to do the adjustment and put the screws back in.
    You will loose a little water but if you have a helper keeping pressure on the skimmer most of the time the loss is minimul. A lot less than if you had to empty and refill several times.
    That's what I would do, Dennis
    Joliet
    Thanks for the replies. I'll give the adjustment a try first (although I will let the water warm up a little )
    thanks,
    dan
    Joliet
    oh boy! I'm starting to get bummed out with this whole pool thing.
    The installer is coming tomorrow to check out the skimmer leak. But (after a long week without rain) I've noticed that the ground in the rear of the pool is wet (the grass was removed...so you see the darkened damp soil).
    I just left a message on his answering machine, to check out the rear of the pool along with the skimmer. But if this is a liner problem...I really don't want to have to fill the pool again...but I don't want to start my pool off with liner problems. I sure hope the installer or pool store (or somebody?) does something about it
    take care all>>>
    dan
    Joliet
    The guy showed uo today, while I'm at work. He told the wife he tightened the screws up and it doesn't leak any more. The wife later asked me if we had caulk on the outside of the skimmer before. Ugh!
    dan
    That's just wrong. Did he say anything about the wet ground? Is it stll wet?
    Later, Dennis
  1. How to repair an IG liner leak at the skimmer interface and replace skimmer
    By ralph in forum In-Ground Pool Construction and Repair
    Last Post: 02-29-2012, 10:37 AM
  2. Help with Skimmer leak.
    By pratzert in forum Above-Ground Pool Construction & Repair
    Last Post: 07-14-2011, 10:02 AM
  3. Skimmer leak
    By dtcdmy4sons in forum In-Ground Pool Construction and Repair
    Last Post: 06-16-2011, 12:13 AM
  4. Skimmer Air Leak
    By stin0000 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-30-2009, 08:17 AM
  5. Leak in skimmer piping
    By waldreps in forum In-Ground Pool Construction and Repair
    Last Post: 06-24-2007, 08:36 PM
