Results 1 to 10 of 13
Thread: skimmer leak
    Default Re: skimmer leak
    It is very possible the gasket just needs to be adjusted a little. Being a new pool it probably does not need replaced. On a couple occasions I have had to go back and do this. I prefer working with a full pool. That way I can see the results without having to wait.
    It is usually a case where the gasket is not pushed down far enough at the bottom. It is very easy for this to happen. I would loosen all the screws slightly and then remove the bottom ones. You may need to go up the sides or you may not. You should be able to do the adjustment and put the screws back in.
    You will loose a little water but if you have a helper keeping pressure on the skimmer most of the time the loss is minimul. A lot less than if you had to empty and refill several times.
    That's what I would do, Dennis
    Joliet
    Thanks for the replies. I'll give the adjustment a try first (although I will let the water warm up a little )
    thanks,
    dan
    Joliet
    oh boy! I'm starting to get bummed out with this whole pool thing.
    The installer is coming tomorrow to check out the skimmer leak. But (after a long week without rain) I've noticed that the ground in the rear of the pool is wet (the grass was removed...so you see the darkened damp soil).
    I just left a message on his answering machine, to check out the rear of the pool along with the skimmer. But if this is a liner problem...I really don't want to have to fill the pool again...but I don't want to start my pool off with liner problems. I sure hope the installer or pool store (or somebody?) does something about it
    take care all>>>
    dan
    Joliet
    The guy showed uo today, while I'm at work. He told the wife he tightened the screws up and it doesn't leak any more. The wife later asked me if we had caulk on the outside of the skimmer before. Ugh!
    dan
    That's just wrong. Did he say anything about the wet ground? Is it stll wet?
    Later, Dennis
    Joliet
    Quote Originally Posted by hrsdennis
    Later, Dennis
    He didn't say a word about it. I figure I'm going to wait until I get home (in the morning) before I jump to any conclusions.
    oh joy,
    dan
    xoroniox is offline Registered+ Thread Analyst xoroniox 0
    South Florida
    Hey,
    After reading what happened i would be pissed off, first you went to a store and bought a brand new kit and installation after paying top dollar you now have a leaking skimmer, small leak but still a leak. and now caulk on the outside which mind you is a sore thumb, not horrible but should not be the case considering you bought new. I would not be happy in your situation and would complain to someone higher in the company. I really hope tightening the screws fixed the problem and the caulk is meant to be there. hope you enjoy the pool!
    just my 2cents
    -Arron
    Talking Re: skimmer leak
    Common problem, I think! We had our pool put in by professional (?) installers about a month ago. I had the same problem, and also could not get any help from the installers or the pool people. What I ended up doing was using teflon tape. Now, I now nothing about pools, plumbing or really anything like that - I am in medical field - but figured that it works on my faucet in the kitchen, so it certainly couldn't hurt! IT WORKED! Then, I noticed all of my other lines leaking slowly, where the gasket is, and did the same thing - now no leaks
