Thread: sand in pool
    Honesdale PA
    Default Re: sand in pool
    I just went back and read your prior post and you said the stuff looks finer than what's in a kids sandbox. That points to the wrong kind of sand. Only suggestion left is to replace the sand. Filter sand is cheap and Carl had some cost numbers somewhere but at this point I'd bite the bullet and just replace. Not sure if it was mentioned but when you replace sand you should fill the filter with water above the laterals, then add sand. This assists in evenly distributing the new stuff and prevents stressing the laterals. Would be nice if you had access to a microscope to investigate this further.
    Southern Ontario
    I figure the sand is so old ( over 15 yrs in the filter) that is smoothed down so much, it is sifting through. A couple of the laterals were loose, so that could have been the problem as well. Off to buy new sand, glad there were no cracked laterals!
  1. replaced sand and now sand is entering pool
    By flomenhoft in forum Pool Equipment & Operations
    Last Post: 07-21-2012, 01:29 PM
  2. Sand Filter dumped all the sand in my pool
    By ib_gman in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-15-2012, 01:16 AM
  3. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
  4. Sand in bottom of pool from sand filter
    Last Post: 06-20-2006, 01:01 PM
  5. Jacuzzi ST-24 sand filter - sand in pool
    By ksturge in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 09:58 AM
