Results 11 to 14 of 14
Thread: Big mistake in trying to raise pH... please help!
    Default Re: Big mistake in trying to raise pH... please help!
    I already said that you had copper in your water.
    Question is, where did it come from? Have you been using algaecide?
    JWB is offline ** No working email address ** JWB 0
    Upland, CA.
    It'll be interesting to see the result of your metals test--if you do have a high metal content you can use sequestrant.....take a look at Marie's (mbar) posts in the metals forum--she's the resident expert and has given lots of good information when it comes to dealing with metals. Is your fill source from the municipal water supply, or is it from a well?
    Thanks Janet I'll check that out. My water comes from a municipal source. From what I understand now, as this kind of water evaporates, the metals are left behind. That probably explains why the water has always had a strange metallic taste since we inherited this pool. I hope I haven't endangered my family by not taking action to correct it. Having never had a pool before, I thought it was normal.
    Upland, CA.
    No algaecide. The only tri-chlor I’ve used was in the two bags of powdered shock (40%), but that was six days ago when I was dealing with algae.
    Actually, you said “it could be” copper so I wanted to get a second opinion. Sorry if it looked like I didn’t read your post. They basically backed up what you said but because I didn’t have a large enough sample, they couldn’t determine exactly what metals are present. I’ll find out later this morning.
    Let’s assume I have an abundance of copper in the water. With the pool’s current state (FC 5+, pH 7.0, TA 90), can I treat the pool with a metal sequesterant, or do I have to get the pool chemistry in order? Also, any chance the oxidized metals are keeping my pH from rising past 7.0 despite 14 lbs. of soda ash?
    Soda Ash=pH Up!=Washing Soda (Arm&Hammer)
    This raises T/A as well as pH. T/A of 90 is nothing to worry about.
  1. Stupid mistake...
    By mkelley in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-04-2008, 06:29 PM
  2. How big a mistake did I make?
    By jojasc in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-05-2007, 11:05 AM
  3. I think I made a mistake
    By dagall in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-28-2007, 10:56 PM
  4. HELP! Made BIG mistake!!
    By DaBomb650 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-22-2006, 12:15 PM
  5. First mistake - added too much CYA
    By mshumack in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-06-2006, 10:28 PM
