I take a 5 gallon bucket and fill it with about 4 gallons of water and pour the muriatic acid in there first to dilute it. THEN I pour the mixture into the return stream, not straight to the bottom.
The stuff sounds scareyI used some dry acid last week to lower my TA but it didn't bring it down enough so I am also considering using muriatic acid with my vinyl lined pool.
It IS a little scary--you just have to follow the rules, though and you'll be safe. Dry Acid isn't as safe as it seems, but it's a lot easier to use than Muriatic Acid. Buy the generic stuff.
Another way to lower your pH is to use Tri-Chlor pucks. But this is only a good way if your CYA (stabilizer) level is lower than you like. Pucks lower pH and raise the CYA level fairly quickly. I use them when I'm in that situation (as I have been this year).
Inground 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWG
As with any acid, it brings down both pH and TA together, though the pH drops more than the TA. This assumes you are using Trichlor for a while so there is chlorine usage/consumption. For example, adding 3 Trichlor tabs/pucks to a 10,000 gallon pool starting out with a TA of 100 ppm and pH of 7.5 would end up with a pH around 7.0 and a TA of 88 ppm. In practice, the pH might not drop that much since there will likely be outgassing of carbon dioxide during that time. The cumulative FC added and presumably consumed is 16 ppm and the CYA increase is 10 ppm.
Don't forget that for every 10 ppm Free Chlorine (FC) added by Trichlor, it also increases Cyanuric Acid (CYA) by 6 ppm.
Richard
Thanks very much, Richard. I chlorinate using a SWG and sometimes have to use muriatic acid to either bring down TA or PH. I've never used a puck before but I assume you have to leave it in a skimmer or feeder for a while and so it sounds like it wouldn't be good for my purposes. I have a vinyl lined pool and I'm still a little nervous about using the muriatic acid. I do pour it into a 5 gallon bucket first and then pour in front of the returns. I also have some dry acid but I hear that's not so good to use with a SWG, but I can't remember why.
The dry acid increases sulfates in the water and that is supposedly not good for SWGs though I don't know why -- probably interferes with (degrades more quickly?) their special coatings on the plates.
