This is a guess but if you had the pool shutdown for the winter and live in a colder climate like I do (Wisconsin), it could have been mouse nest. Happened to me 3 years ago. There was a nest built on the burners and another above the heat exchanger. The little buggers chewed through the insulation and used some of that to make the nest. Now I check it every spring before firing it up.
