Thread: PS 233 - I need the reagents
    Default PS 233 - I need the reagents
    Hi guys - I have an old test kit and wanted to just get the reagents and not pay for the box and test tubes etc. I would like to get an extra CYA test reagent (R-0013). Where should I order them? Is the TF100 test kit the same? They have a restock price of $35. Are they the same reagents? Thanks!!!!
    Default Re: PS 233 - I need the reagents
    My fault...I did not do a proper search before. My sister and I compared the two and then I found the answer here. We will just get the refill from TF and we then have a couple of extra things which we will not use (or can we?). Anyway it is now ordered and we can get back on track.
    Honesdale PA
    You can also get bulk refills here:
    http://www.spspools-spas.com/
    TF Tstkits use Taylor reagents so you can order reagents from them. In fact, the refill kit for the TF100 would be exactly the same reagents needed for a PS234
    Quote Originally Posted by Poconos View Post
    I've ordered from this company many times and really like their prices, available quantities, and service.
