Thread: Where is the waste setting?
    Default Where is the waste setting?
    The sticker is gone from the top of my Hayward S244T sand filter and I don't remember where the "waste" position is.
    I do know that:
    Normal is at 12 o'clock
    Backwash is at 6 o'clock
    Rinse is at 11 o'clock
    Waste position is
    ivyleager is offline Lifetime Member Weir Watcher ivyleager 0
    North Carolina
    Default Re: Where is the waste setting?
    Just ran out to confirm: on my Hayward Sand filter, waste is 1 oclock. All my other settings match yours exactly.
    CaryB
    1:00 it is! I have a Hayward as well. You may want to label it, or engrave it into the plastic --a single letter should do. N, W, B, R, C for normal, waste, backwash, rinse, closed.
    North Carolina
    Quote Originally Posted by CarlD
    Carl & Bass,
    Do either of your filters have the WINTER position between waste and backwash? Mine has 7 settings as follows:
    Filter/Normal (12 o'clock)
    Waste
    Winter
    Closed
    Backwash (6 o'clock)
    Recirculate
    Rinse
    Just wanted to clarify.
    CaryB
    Honesdale PA
    I have a 244T also...no Winter setting. Think I heard that it's just an intermediate position that keeps the handle lifted so all ports are open and no pressure is on the valve gasket. Same as leaving the handle between operational settings. Best guess.
