Re: Yellow Staining
First I am really surprised that your ph stayed that high using the ascorbic acid. Your ph was probably even higher than you thought. It usually takes the ph way down. Second, you didn't say you put in any sequestering agent. You will need to do that asap - it should also take the ph down. Anytime you have your ph above 7.4 and you have metals in your water, when you add chlorine the metals will fall out and stain the surface of the pool. If you are having algae problems, then you need to add the sequestering agent, make sure your ph is no higher than 7.2 and then shock. I would also use some algaecide because it is hard to keep chlorine levels up after doing an ascorbic acid treatment. The remaining ascorbic acid eats the chlorine.
Northeast PA
