Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 48
Thread: Skimmer Socks - Thoughts???
    Jul 2006
    SE Georgia
    Default Skimmer Socks - Thoughts???
    I just installed a skimmer sock on both skimmers.
    They're designed to catch the "finer" debris and keep it from going to the pump/filter.
    Anyone have any experience with these they'd like to share?
    40'x28' I/G L-shaped, vinyl liner pool, with an estimated 40,000 gallons of water.
    Been using BBB for over a year! Excellent results!
    ivyleager is offline Lifetime Member Weir Watcher ivyleager 0
    North Carolina
    Default Re: Skimmer Socks - Thoughts???
    They work great. You'll be surprised how awful the skimmer socks look when you pull them out to clean. YUCK.
    CaryB
    Lehigh Valley, PA
    They're great!
    On my system, when the pump isn't running, the bottom of the sock floats up and some of the debris it had caught, dislodges. I now put a small rock inside the sock so it stays down in the skimmer basket when the pump is off.
    I've been using them for 3 years. They work great and reduce the number of times you backwash. I replace the sock about once a month--cheap enough!
    We use them too and love the "polishing" it does by getting the finer crap out of the water. FYI - you need to check them often to be sure they don't clog up - not much gets through those buggers and they can quickly clog up enough to change pump pressure if there is pollen or other junk floating around.
    Lehigh Valley, PA
    Once a MONTH? I change mine daily. Of course, I get a lot of dog hair in the pool but even without the dogs, like a few days ago, I had something like a gazillion flying ants in there. Must have been a hatch. And during pollen season it got disgustingly full of yellow pasty gunk.
    Changing the sock is part of my daily routine. I rinse it off with the hose, hang it over a fence post, and put another one in the basket. Once amonth? Man, you have CLEAN water!
    Jul 2006
    SE Georgia
    Excellent ideas!
    Thanks!!
    Quote Originally Posted by AnnaK View Post
    I didn't say I CLEAN it once a month--I said I REPLACE it once a month. I CLEAN it every single day, and in late May early June twice a day (heavy pollen). After a month it gets pretty worn out and I throw it away. Why do you bother to dry it on the fence post?
    salinda is offline Lifetime Member Weir Watcher salinda 0
    San Jose, CA
    It definitely cleans, but the pool was getting too high maintenance and as a busy mom I can't check this daily. I have a micron cartridge filter and my water was pretty clean without this, so I removed mine.
    Salinda
    North Florida
    And if it's not dog hair or flying ants, it's spiders, June bugs, or worse! It also helps to keep my pump strainer basket cleaner. Wouldn't have a pool without skimmer sox.
    Sandy
