Thread: Pool Filter Sand
    Default Re: Pool Filter Sand
    That is probably one of the synthetic sand substitutes, similar to Zeosand, but I'm not sure. Since it came from a pool supplier, it's probably okay to use, but I would either call the number on the package for the manufacturer or double check with another pool store to make sure before you use it.
    I don't think it was a substitute. It's only $10 a bag...
    this is the picture of the differences between the sand:
    Oh, OK. I think it should be fine. I've seen black-flecked sand. The grains and shape look similar despite the color. It's probably just the source quarry or whatever of the sand that dictates its color. Even mason's sand can come in white, yellow, red or black (and probably some other colors, too.)
    Confirmed by MFG and Pool Company that it is indeed #20 silica sand. Odd that it wasn't marked as such anywhere.
    Just curious-why did you remove the "old" sand?
    Hal
