Thread: Multiport repair
    Default Re: Multiport repair
    Well, we installed new gaskets in two multiports yesterday, both dry/ no glue. One of them worked and one of them immediately distorted and leaked. Both are shut down right now. I'll go by and play with them this morning. Do you think a multi could become warped? When I've got the most troublesome of the two older ones apart, everything looks good and I tell myself that there's no reason to replace it, but I'm on the verge of ordering a new one....
    Hal
    The one time I had to replace it, I used a lot of gasket lube, not glue. That was two or three seasons ago. So I'm on my second spider in 7 seasons.
    Did you lube the bottom of the channel the gasket sits in? Did you lube the hard upper surface that seals against the gasket? I've never lubed any that I've worked on at all. Thanks
    Hal
