I guess i see if its covered under warenty.
thanks-
thanks-
Very strange to only be in the corners like that...
Can you feel the area and tell us if it might possibly be calcium deposits or similar - ie - something that is on the liner (perhaps tape residue?)
Logic would say that any cracking would be ~ the same around the entire liner, but then again, so should any deposits![]()
Please keep us posted as to what you find out about this![]()
Hi waste it is happening at the same line level on 90% of the liner all around the pool.
the only thing i can think of is when i had a alge or slim problem i scrubed with a pool scrub brush. but i did that to 100% of the walls. this is happening above the waterline;(
Did you use any type of chemical when you were scrubbing with the pool brush that may have not been rinsed off above the waterline?
