Results 1 to 10 of 11
Thread: Fading liner help.
    Default Re: Fading liner help.
    Very strange to only be in the corners like that...
    Can you feel the area and tell us if it might possibly be calcium deposits or similar - ie - something that is on the liner (perhaps tape residue?)
    Logic would say that any cracking would be ~ the same around the entire liner, but then again, so should any deposits
    Please keep us posted as to what you find out about this
    Jul 2006
    Hi waste it is happening at the same line level on 90% of the liner all around the pool.
    the only thing i can think of is when i had a alge or slim problem i scrubed with a pool scrub brush. but i did that to 100% of the walls. this is happening above the waterline;(
    Did you use any type of chemical when you were scrubbing with the pool brush that may have not been rinsed off above the waterline?
    Jul 2006
    you know maybe by dumping over 10 gallons of bleach in the pool(11,000 gallons)and scrubbing right after that might have caused this-
    watcha think?
