Thread: compu pool SWG
    Scottsdale, Arizona
    Default compu pool SWG
    Anyone have any experience or opinions on this unit?
    http://compupool.com.au/product/salt_wa ... aning.html
    14'x31' kidney 21K gal IG plaster pool; SWCG (Saline Generating System's SGS Breeze); Pentair FNS Plus 48 DE DE filter; Whisperflow 1 HP pump; 8 hours hrs; kit purchased from Ben; utility water; summer: none; winter: none; PF:5.7
    May 2010
    Default Re: compu pool SWG
    I have recently installed the Compu-pool CPSC-24. I Can't get your link to work, possibly because I am in the restricted group due to being a newbie so I am not sure if your looking at the same unit. However, I have only had my unit for a couple of weeks, but so far so good. I called the toll free number to learn how to program it because the instruction pamplet is a little weak. So far I am pleased with the unit and it has kept my pool sparkling clean since it was installed. I only paid a little over $600 USD for it plus installation. I would recommend this one. One tip my installer told me was to get a SWG unit that is rated for a pool twice the size as you actually have so it does not have to struggle to keep the chlorine levels up. You can always adjust the actual time the generator is working with the timer.
