Re: Aqua Rite = Amperage
vicar8
My new Aqua-Rite is not producing chlorine. I noted on the diagnostic that the amperage reading was running about 3.21 to 3.45 which is lower than what is the proper operating level. How do you fix this?
Also, I found it strange that I had to go to the WEB to find our what the correct operating volt and amperage ranges are since the manual that came with the system failed to include them.
I don't remember whether I got this from the Goldline manual or somewhere else:
Cell voltage 22-25 v when chlorinating else 30-35 v
Current 4.5 - 7.8 amps when chlorinating else 0 amps
The amperage of your SWG cell may be within normal operating limits if the water is cold. On my system 50° F. water and lower levels of salt (~2500 ppm) will cause the applied voltage to read 27.17 volts 3.30 amps.
It seems that both Goldline and Pentair manuals tend to be a bit skimpy on content... very frustrating when you're trying to diagnose a problem with an error code that isn't documented or just attempting to establish a baseline for future troubleshooting.
16'x29' free-form 14K gal IG gunite pool; SWCG & sodium hypochlorite 8.25%; Hayward SwimClear C4025 cartridge filter; Hayward SP3202VSP TriStar Variable Speed Pool Pump; custom test kit based on Taylor K-2006C; city; PF:8.6
